Since there doesn't seem to be a way to get ECUMaster EGT to CAN to connect with my Megasquirt2 unit is there a way I can get the EGT/CAN software/program to start logging automatically or if a certain parameter is met?
I can "start logging" while in the program but need it to start logging at the start of a run in the race car...any ideas?
Triggering CAN-EGT logging ??
Re: Triggering CAN-EGT logging ??
I have the EGT to CAN plugged into a computer under my dash using a USB cable. It connects and work perfectly through the USB cable. I can get it to start logging by hitting SHIFT+F9 ....obliviously it stops logging when I hit SHIFT+F9 again....
Does ANYBODY have an idea how I can do this myself inside the racecar right before I stage? I don't have a keyboard or monitor in the car when I'm racing so it would have to be on a button OR if the program could be made to start logging after the EGT temps get up to 1000* F for instance?
I tried using the RaceCapture software but I guess it won't run because I'm only using the EGT to CAN module....
ANY IDEAS ?? PLEASE
ANY IDEAS ?? PLEASE
Yes you can setup parametric logging. So you can define conditions for logging start and stop. For example temp, speed or any other conditions.
