WHICH ECU VERSION AND ADDONS FOR MY PROJECT?
Posted: Tue Jun 23, 2015 8:32 am
Firstly my project is a custom project.
Wild street car and track mostly.
1995 R33gtr Modified in Japan before being shipped to me in Australia.
Triple Compound Turbo Rb25/30 engine
Head
Rb25de head ported and polished
Tomei Pon 272 10.5mm lift cams
Tomei solid lifters
Tomei oil restrictors
Tomei head oil baffels
Brian Cower valve springs
Brian Cower gtr +1mm valves
Hi Otcane Head to sump oil drain kit
Split Fire coils
CRYOGENICALLY TREATED PARTS
Rb30 block, cleaned honed bored
Rb30 balanced and knife edged crank
Spool conrods
Kings bearings
Acl rings
Nitto 87mm forged pistons comp ratio 8.7:1
Gudgen pins
Arp bolts and mains
Maincaps
Valves
Lifters
OIL SYSTEM
Barnes 5 stage dry sump pump
20 litre oil tank
Accusump installed pre turbos
22"×4" Oil cooler for engine Oil
6"×4"Oil cooler for transmission
6"×4" Oil cooler for rear diff
COOLING SYSTEM
Custom 4 Core 100mm radiator,
Twin thermo fans
N1 water pump
Davies Craig electric water pump (backup)
Co2 System (to aid extreme temps)
FUEL SYSTEM
Bosch 044 twin fuel pumps feeding 2L swirlpot
Earls braided everything......
Injector Dynamics 1000cc Injectors
INTAKE
6" Cold air intake
Feeding Borg Warner S400 sx3 467 T6 Turbo (LP TURBO)
Feeding Twin R33 Gtr N1 Turbos (HP TURBO)
4 HKS SSQV Plumb back Bov's
4" Fully welded Aluminum Piping
Feeding Air to Air intercooler with water sprayer
Feeding to Water to Air Cannon Cooler
Twin Z32 MAF Sensors
Into Rips Custom RB25 intake with Q45 throttle body(cable operated)
EXHAUST
Tomei twin exhaust manifolds
Feeding twin R33 GTR N1 Turbos internal waste gates
Custom 3" dump pipes
Feeding into 3" to 4" Collector
Feeding T6 Borg Warner S400 sx3 467 Turbo
50mm waste gate
Into a custom 5" Piping and Tomei Exhaust
This car originally was tuned with a motec ecu, for 750rwhp and had a Q45 throttle body.
I recently purchased the LS2 electronic throttle body, and am seeking some advice on the correct ECU and additional hardware that I would need to add drive by wire to my vehicle.
Motec gear is good, but after a serious disagreement with them over their products and the way they ruin their business,
Its time for a change.
I have heard nothung but quality reviews about this product line and would like to join the long list of consumers and contributers.
I am seeking the correct Ecu and products to install on my pride and joy to accept the throttle body,map sensor,2 step,flat shifting,launch control etc...
Kind regards,
Tidy8
Head
Tomei solid lifters
Split Fire coils
Spool conrods
Kings bearings
Acl rings
Gudgen pins
Arp bolts and mains
Maincaps
Valves
Lifters
OIL SYSTEM
20 litre oil tank
COOLING SYSTEM
Twin thermo fans
N1 water pump
FUEL SYSTEM
INTAKE
6" Cold air intake
EXHAUST
50mm waste gate
Kind regards,
Tidy8
