1JZ Lexus IS200
- tommyboyblitz
I have started a build with a 1jz going in my lexus is200, i am using the emu master ecu, i know very little about mapping, where can i get a start up map? thanks
- Kisielisodd
- ECUMASTER TEAM
Re: 1JZ Lexus IS200
You can get startup map from Your local ECUmaster dealer. Also search in forum 1jz and 2jz share configuration.
- tommyboyblitz
Re: 1JZ Lexus IS200
ok thanks, i spoke to graham?, he said he was sending me a map then dissapeared??
Re: 1JZ Lexus IS200
search on this forum works quite fine : viewtopic.php?f=19&t=490&p=3345&hilit=1jz#p3345
tommyboyblitz wrote:ok thanks, i spoke to graham?, he said he was sending me a map then dissapeared??
