JZX100 1JZGTE VVTi MANual ;-)
JZX100EMU
Post by JZX100EMU » Sun Apr 24, 2016 11:32 am
Hello all,
I'm currently starting to wire up the EMU into my JZX100 Chaser.
I found the pin-out for the JZZ30 1JZ VVTi Soarer and am now converting that to the JZX100, I just hope all will be good...
Engine Speclist is as follows:
TOMEI m8280 turbo
Siemens Deka 830 cc/min injectors
GReddy FMIC
HPi Downpipe
200 CPSI catalytic converter
HKS cat-back
AEM fuel pressure regulator
Walbro 255 lph fuel pump
any advice for me, pin-out wise?
I believe this is the correct pin-out
http://s50.photobucket.com/user/ace1312 ... 1.jpg.html
Any help is greatly appreciated as I'm worried about not having all the sensor characteristics. Anywhere I could find those?
Cheers,
JZX100EMU
Re: JZX100 1JZGTE VVTi MANual ;-)
Post by JZX100EMU » Sun Apr 24, 2016 6:00 pm
https://www.dropbox.com/s/u2v6bkjezhhy3 ... .xlsx?dl=0
Could someone check if this pinout/wiring setup for the JZX100 1JZGTE VVTi is correct?
Would be greatly appreciated.
JZX100EMU
Post by JZX100EMU » Sun Jun 26, 2016 1:14 am
I'm curious as to why my settings don't seem to work.
Setting screenshots, logs and scope can be found here.
https://www.dropbox.com/sh/iay1anbyei5z ... nIdea?dl=0
I would really appreciate any help.
I assume my primary trigger setting is wrong
I have checked spark presence (my timing light is dead so can't check ignition timing sadly)
Fuel pressure is good (43-ish psi)
Thanks in advance.
Post by PSI-Motor » Sun Jun 26, 2016 3:45 pm
Get a new timing light its quite important.
JZX100EMU
Post by JZX100EMU » Sun Jun 26, 2016 4:20 pm
PSI-Motor wrote:Get a new timing light its quite important.
I know that's why I've set out to buy one... only to find out the shop I went to (only one open today) doesn't have one in stock!!!
really frustrating
Thinking about getting an PC-based 2 or 4-channel oscilloscope too
tommyboyblitz
Post by tommyboyblitz » Mon Oct 17, 2016 9:55 pm
From your files you do not seem to have a secondary trigger from the inlet cam?
These are my settings, i hope this helps
1jz gte vvti 3-5-16 higher dwell toyota coils.emu
1JZ GTE vvti JZX100
(95.41KiB)Downloaded 55 times
tommyboyblitz
Post by tommyboyblitz » Mon Oct 17, 2016 10:03 pm
This is my scope - There would be a 3rd pulse on the secondary trigger which coincides with the gap on the primary trigger this sets your tdc for the computer to work out where everything is. From your scope you do not have a secondary trigger.
Hope this helps
scope_20161017_211.emuscp
scope
(248Bytes)Downloaded 58 times
Last edited by tommyboyblitz on Mon Oct 17, 2016 10:08 pm, edited 3 times in total.
tommyboyblitz
ooops
Last edited by tommyboyblitz on Mon Oct 17, 2016 10:06 pm, edited 1 time in total.
tommyboyblitz
ooops
