s14 silvia 1.5jz
Posted: Tue Jun 07, 2016 1:41 pm
hey guys, few pics from my build of my car, it has been running a 1jz gte with holset and greddy emanage for 2 years now, I've decided to fully rebuild a 2jz block with a big port 1j head and cams, then use a new turbo and emu stand alone for a bit more fun
car was completely stock when I bought it and I've done a full shell rebuild from ground up
looking for a base map for my ecu as my supplier is being a bit off with sending me a base map for some reason, it's a 1.5jz, 264* cams, 800cc sard side feed injectors and either bosch audi coil packs or bosch fiat pencil coil packs
bosch knock sensor, I was told by my supplier I cannot use the stock Toyota one, I was also told only to use one of these. shouldn't I have two as the factory Toyota setup has two?
Bluetooth sensor
oil temp sensor, does it matter which wire the resistor goes into? I have not read the instructions yet
oil pressure sensor
air temp sensor I was told to buy, unsure on make
new engine gasket set
oil and water pumps, belts and tensioners etc
all new engine sensors (bar the ones from emu)
piston oil jets
brian crower head parts
new clutch kit for bmw conversion
the car:
current engine:
Bluetooth sensor
oil pressure sensor
piston oil jets
the car:
current engine:
