MK2 escort - SR20DET + DET3
retro-ed
Post by retro-ed » Tue Sep 23, 2014 10:51 am
Hi All,
I have a MK2 escort which I have fitted a Nissan SR20det engine to and use for drifting and as a road / track toy
Here is the build thread:
http://www.driftworks.com/forum/drift-c ... rt-26.html
Every thing on the car has been done by myself in my shed so when it came to ecu mods, the DET 3 unit looks perfect until I can afford an EMU ECU.
The engine is currently running the standard Nissan tune and ECU. I have fitted the turbo from an Evo6 and made a few other tweaks so I now need to tweak the fuelling to get it perfect.
Tonight I will be fitting:
-Det3 Unit (4bar internal map sensor version)
-AEM Wideband gauge and controller
I will be doing the tuning in stages, hopefully ending up using the DET3 in fuel implant mode, without an AFM. As a start point though, I plan to use it in the basic mode, configured as follows:
Analog input #1 - AFM signal (0-5V)
Analog input #2 - Wideband signal (0-5V)
Analog input #3 - Not connected **need to earth?*
Analog input #4 - Not connected **need to earth?*
Power out #1 - To –ve side of boost solenoid
Power out #2 - Not used
The wiring to the engine loom is different to the S14 layout on ecumaster.com as I am using a S14a Ecu / loom. I will post up a picture of the revised pin numbers.
I have had a little play with the software already so am looking forwards to being able to use it on the car.
Cheers
ktsirigotakis
Re: MK2 escort - SR20DET + DET3
Post by ktsirigotakis » Sat Sep 27, 2014 11:03 am
Hi my friend i have tune my friends s13 with sr20det with vtc black stock two years ago using det3 400kpa peggy pack mode i can send you my tune. In octomber i will change it to FIT mode is much better i suggest you to do the same. also analog 2 is the internal map of det3 connected.
usualy when i use peggyback mode i wire them as:
analog1: map/maf in
analog2: not use due to internal map (dont ground it leave as it is)
analog3: lunch contorl
analog4: wide band in
if you dont use analog input better to ground them .
probably you will need injectors upgrade sr20 are to small to run big boost
retro-ed
Post by retro-ed » Wed Oct 01, 2014 10:42 am
ktsirigotakis wrote:Hi my friend i have tune my friends s13 with sr20det with vtc black stock two years ago using det3 400kpa peggy pack mode i can send you my tune. In octomber i will change it to FIT mode is much better i suggest you to do the same. also analog 2 is the internal map of det3 connected.
analog1: map/maf in
Hi!
Cool, that would be awesome if you could send me your files 
What RPM did you find it reved to as standard? I thought the limiter was near 7500rpm but DET3 is only saying 6950 rpm
I would like to fit bigger injectors next and remove AFM. I would love to know how you get on with FIT mode as that is something I would like to do.
I got the car running last week, just in time for the final round of the drift series I compete in. I did some very rough road tuning to the fuel table to make sure it wasn’t too lean on boost and so I was confident it wouldn’t melt. It was by no means perfect but was better than it was before  I haven’t touched the timing table yet.
AEM Wideband in and wired through DET3
Connected and running
Car performed very well at the track (Pembrey in Wales). Car took a lot of abuse (final corner is 4th gear, rev limiter) but performed perfectly. I managed to win!.
Next up is to do some proper logging and mapping. I would like to do a maf to map conversion but the first time I tried it didn’t work (I didn’t have any more time to investigate)
Cheers!
retro-ed
Post by retro-ed » Wed Oct 01, 2014 10:45 am
For info, unit now set up as follows:
Analog input #2 - Internal map sensor **external wire not connected*
Analog input #3 - Wideband signal (0-5V)
Analog input #4 - Not used yet **earthed*
retro-ed
AFM to MAP Conversion
Post by retro-ed » Thu Oct 02, 2014 9:09 am
I started playing with th eAFM > MAP conversion setup last night..
Staring with a log I took the other day I clicked "MAF > MAP conversion"..
Then the configs were set as follows.....
Which gave this fuel map as a start point...
I then spent some time filling in all the holes and generally smoothing the map around cells which the log suggested were OK. The area around idling was tidied up a bit and I tried to get it nice and smooth. This is what I ended up with:
I uploaded it to car last night. Hopefully I will get chance to try it on the road tonight and start building on it.
Kisielisodd
ECUMASTER TEAM
Post by Kisielisodd » Fri Oct 03, 2014 11:16 am
looks great, it will work :)
retro-ed
Post by retro-ed » Fri Oct 03, 2014 3:19 pm
Drove it to work this morning with MAP (AFM still there, just connected) and it worked 8-)
Did some really rough tweaks to make sure it was safely rich up top on boost then gave it a few full throttle pulls on the way home....
Lots of work to do to the map now but I am so happy it is running that well :) It drives very smoothly as well whereas it would sometimes stutter with the AFM (maybe because it was so close to turbo??)
retro-ed
Post by retro-ed » Wed Oct 08, 2014 4:18 pm
Bit more tinkering...
Still needs more fuel in the mid range but it is getting there!
ktsirigotakis
Post by ktsirigotakis » Fri Oct 10, 2014 3:48 pm
you are going very well Bravo now it will work now your next step is to FIT mode :D
sorry but i was very busy tuning my car and my friend car for the dragster event that we had the weakened
retro-ed
Post by retro-ed » Tue Oct 14, 2014 5:10 pm
Indeed, FIT mode will be the project for spring when I have a bit more time.
I have some larger injectors coming so will fit those and tweak the map.
I would also like to sort the boost control, using DET3. At the moment it is using a ball and spring type manual boost controller. This is not giving very good control.
Cheers
retro-ed
Post by retro-ed » Sun May 17, 2015 9:06 am
latest spec:
Still in piggyback mode
256deg 11.5mm lift Cams
SARD 550cc injectors
no AFM
ktsirigotakis
Post by ktsirigotakis » Wed May 20, 2015 2:12 pm
nice well done!!!! keep going!!!! i will convert my friends sr20det from peggy back mode to fit mode and i will post you also i bought sr20de+t and making it forged for my s13 but i use EMU
