I know, i asked about the tps settings. fuel cut tps % under, idle on tps % under etc.Jadzwin wrote:Actually resolution 0.5 for VE and Ignition table is available.
Bugs and Feature reqests
Re: Bugs and Feature reqests
it would be possible with resolution of 0.5
Jadzwin wrote:it would be possible with resolution of 0.5
It would be ok too i guess. It will help a lot with driveability for those who use the ecu in their every day cars.
Is it possible to add ON/OFF switch input option for traction control, using inputs SWITCH #1...#3?
Currently user can only choose analog input for adjustment. This can be used as ON/OFF signal, but then user loose one analog input.
Just set "ADJ scale" to 0 on position 1 and TC is OFF
Do you plan to expand it so that it can support automatic transmission?
Bug Can Analog Input
In the settings we use can analog 7+8 for boost blend and tc.
At blend cal and tc cal all the same as input 7
in attachment you can see the bug
can you explain it more ?
on analog can 7 we have 10 step switch for TC
on analog can 8 we have 10 step switch for Boost Blend
on Analog Inputs we can see the correct voltage for analog can 7 and 8,
on boost blend cal and TC cal it shows all the same as analog can7
analog can 8 has no function in boost blend, but i see the correct voltage for the input on the Analog input.
If you want you can look with teamviewer on my car
Will there ever be the ability to tune wirelessly via EDL-1 BLE interface? This is one feature I miss.
Dont think so, for safety reasons.cmj wrote:Will there ever be the ability to tune wirelessly via EDL-1 BLE interface? This is one feature I miss.
did you checked the errorNo Limits wrote:on analog can 7 we have 10 step switch for TC
Can you send me a quick fix.
It is already fixed. The version will be available today 2.027
with firmware 2027 it looks the same errorNo Limits wrote:on analog can 7 we have 10 step switch for TC
So i don't understand what you are mean.
There was a bug that you cannot use CAN ANALOG inputs for boost blend (when selected). Now it blends with analog inputs and CAN analog inputs.
look at pictureJadzwin wrote:So i don't understand what you are mean.
Can Analog 7 is 1,65 Volt- and TC Cal says 1,7 Volt. This is OK
Can Analog 8 is 4,43 Volt and Boost Blend Cal says 1,7 Volt, it is the same as TC Cal and this is wrong
Any news with the TPS settings resolution increase and the Honda F20C engine sync from both cam sensors during cranking?
Blendig is working correct, only cursor on x axis for boost blend table is incorrect.
No Limits wrote:look at pictureJadzwin wrote:So i don't understand what you are mean.
Not yet, but it is on the list (especialy F20C start)
nickbmw wrote:Any news with the TPS settings resolution increase and the Honda F20C engine sync from both cam sensors during cranking?
Looking forwardJadzwin wrote:Not yet, but it is on the list (especialy F20C start)
