Hi guys,
please educate me on the subject.
2jzgte supra, i had 872cc low impedence (2,4ohm) injectors with stock resistor pack, needed for when i was on stock ecu with just a piggyback ecu.
Now on Emu Black, may i benefit from removing the stock resistor pack? In case i've to modify settings in the config?
Adriano
2jzgte, low impedence injectors and resistor pack
Re: 2jzgte, low impedence injectors and resistor pack
Probably a dumb question, no one replied
Take a look to EMU Black booklet.pdf
EMU Black is for high impedance injectors so you need resistor pack.Injectors up to 8 HiZ injectors
It was dumb indeed
Thanks!
Thanks!
