EMU BLACK information
Support for EMU BLACK device
turbofreak
Re: EMU BLACK information
Post by turbofreak » Mon May 22, 2017 8:56 pm
How much amperage can either of the 5 volt regulators supply?
Post by Jadzwin » Wed May 31, 2017 4:33 pm
500mA is safe value
Ort
Post by Ort » Fri Jul 14, 2017 9:45 pm
I have a few questions about how to go with the harness first time that I do this,
1-What I'm gathering is that Pins B29 B38 B39 are sensors grounds and I should ground all my sensor to this 3 pins
2-The power to the sensors come from the fuse box
Example E85 one pin is 12v from the fuse box, the other is ground so that can go to the emu black B29 and the signal to B9 on the emu black
3- the only time you don't get the power from the fuse box is when it is 5v from the ecu
Example Q45 TPS it has a 5v ref that can come from B26 the input to the ecu goes to B18 and I can use the same ground B29 and is there a fuse anywhere between the ecu and the TPS sensor
Mikekrus
Post by Mikekrus » Fri Sep 15, 2017 5:31 am
Does the ecu have a built in barro sensor as well? To adjust fuel based on elevation / altitude?
The stock Audi EGTs use a 5V signal is there anyway to wire those into the ecu?
Post by PSI-Motor » Sat Sep 16, 2017 12:47 am
Yes.
No.
RasPL
Post by RasPL » Sat Oct 14, 2017 1:28 pm
Can someone explain in details how definied CAN stream is working ? I can set ID, DLC. baudrate i supose is taken from interface configuration site.
Now i can set type Rx or Tx. Rx is very small section.
At TX data how can i choice correctly parameters ? Is too much and from where should i know the selected parameter bit/byte width etc?
Can you add more parameters to the Rx ? Virtual inputs, boost blend etc. I can make own modules and i bought black because of can support.
Zazzn
Post by Zazzn » Sat Apr 28, 2018 11:11 pm
Is there any way to alert for software updates?
MoneypitKA24DET
Post by MoneypitKA24DET » Sun Sep 23, 2018 5:10 am
Quick question what is a safe amperage 12volt power for the ECU?
Post by Karel » Thu Sep 27, 2018 10:20 pm
:idea:
MoneypitKA24DET
Post by MoneypitKA24DET » Sun Sep 30, 2018 7:01 pm
If you are going to try to ridicule someone or talk down to them try switching on some spell check?
