+1daniel@post-haste.ca wrote: ↑Fri Sep 15, 2017 11:54 pmAre we likely to see Toyota early CAN-BUS communications start to be supported? I believe they call in "BEAN" and is in most of the JZ swap platforms from around 1999.
LINK ECU's already have the ability to access the network so currently has one up on those of us trying to use the ECUMaster EMU Black
Some information on the system can be found here:
http://wilbo666.pbworks.com/w/file/9341 ... cation.pdf
http://wilbo666.pbworks.com/w/file/9341 ... EAN%29.pdf
Bugs and Feature reqests
Re: Bugs and Feature reqests
Actually we do not plan to add Toyota specific communication
BUG with the virtual output 3 hysteresis. Actual hysteresis is always 11, no matter what value typed in the hysteresis field. Can you please fix this?
Virtual output 3 is only output that can be used for IDLE pid activation. I added video into the facebook group about this issue.
Feature request:
1) Two switchable staged injection maps - selectable by map switch, or other means.
2) Sequential staged injection.
With this i could make bi-fuel (Gasoline+LPG) with one ECU.
Injector output count on EMU Black is totaly sufficeint for 4 cylinder engine
Or even tri-fuel with Flex-Fuel
Hello, is it possible in future Software to have a Missfire Detection per Cylinder? Also in Emu Classic.
Missfire Detction like OBD . " Missfire on Cylinder 2 detected "
Best Regards
Frank
Frank
Hi.
Could you implement PID regulator on parametic output? I would like to run a Pierburg cwa200 electric waterpump and set a specific coolant target. The pump is controlled with PWM signal 150Hz 12V
- GearTech_Greece
Any chance you can make idle ref table 3D? (TPS, coolant, idle duty). This way, the idle RPM ref table is not needed and may be deleted.
Also idle target RPM can be upgraded to 3D (TPS, coolant, RPM target). This prevents duty cycle reduction from PID controller when throttle is slightly pressed.
In both cases, not many TPS rows needed, 2-3 are enough.
Parametric Outputs can be useful for many things so I think expanding on this a little would be helpful for complex setups. Can a "Variable operator" option be added for between two values?
Something like VSS between 50 and 100 or RPM between 500 and 5000 could be useful.
Also adding a few more logical operator levels might be nice especially if relying on those for the "between" function.
Maybe one is easier than the other.
Are there plans to add a "long time knock ignition retard map" ?
I mean an additional map that record knock events and apply constant ignition retard at this map/rpm. Then you can see where in the main map corrections must be made.
