I change EMU to EMU BLACK and i have problem with WBO.
I do not know it's a problem with the WBO or connections or setings.
Can anyone check log.( I change filename .emublog to .emulog, forum no support new format.)
Wide band LSU 4.2 - problem
- 20170114_1657-wbo.emulog
- (27.78KiB)Downloaded 82 times
BMW e30 M50B25 +turbo
Re: Wide band LSU 4.2 - problem
EMU uses 5 wires, EMU BLACK 6 form the Lambda ...... do you have all wired in ?
Looks like broken sensor or broken EMU
I've wired 5 to the EMU black, and the sixth to fused/switched 12V.. Am I incorrect in this?Karel wrote:EMU uses 5 wires, EMU BLACK 6 form the Lambda ...... do you have all wired in ?
Sounds ok
