Launch control settings
Support for EMU BLACK device
nickbmw
Post by nickbmw » Sun Apr 02, 2017 12:20 am
Guys, do you have any launch control settings to share, that will keep nice and steady rpm? For an n/a engine, no boost.
samvel
Re: Launch control settings
Post by samvel » Sun Apr 02, 2017 9:17 pm
Just try and play with settings.
It`s very easy especially as you have n/a application. It will be basically just "revlimiter" in your case. You can play at lower rpms, to not stress valvetrain too much. When you find good settings set where you want it to be.
nickbmw
Post by nickbmw » Sun Apr 02, 2017 11:30 pm
That's my point, i don't want it to be simply a rev limiter, a hard cut. I want it to behave like this : https://www.facebook.com/romainlevesque ... 739887645/
samvel
Post by samvel » Mon Apr 03, 2017 8:20 am
revlimiter can be done differently, so play with settings and find out.
nickbmw
Post by nickbmw » Mon Apr 03, 2017 2:40 pm
I experiment a lot in general, but i would prefer a starting point on this one as it stresses the engine a lot
Post by Karel » Tue Apr 04, 2017 10:44 am
nickbmw wrote:I experiment a lot in general, but i would prefer a starting point on this one as it stresses the engine a lot
You can do fuel cut, ign cut, ign retard and all combinations
I think in most cases the fuel cut should make less stress.
IGN cut is very fast, but you can end with huge bangs, destroing your exhaust valves, exhaust manifold etc...
IGN retard slows the engine by reducing its torque, but generates heat on exhaust valves and exhaust generally...
So the correct combination for me will be (may be not for you) : Slight ign retard and dont step on full gas like Monkey.
You can apply so much gas until you hear the engine want rev more (bacause retarded timing). If you push harder on gass, you will just make more stress on the engine, so i think this will be just stupid to do it.
If it is for stupid custommer, i would combine the retard + fuelcut few revs above the retard...
And if it will be turbocharged car, i would combine the retard with ign cut, to make boost off the line....
You can also you DBW, and this can make thing much nicer....
Like Samvel writes.... there are many ways, you need to decide what do you want.
nickbmw
Post by nickbmw » Wed Apr 05, 2017 12:42 am
Very informative post, thanks a lot.
