Rx8 Canbus extras?
Posted: Tue May 09, 2017 1:50 am
Most doing an engine swap with the rx8 will be drawn to ecu masters emu Black because of the ability to control the dash
My question is, apart from what's stated in the manual like CEL, coolant, rpm, speedo, oil preassure light.
Can we get added the ability to turn off lights such as
Electronic power steering warning
DSC and Traction control
ABS
These will be vital for most as doing your swap you often delete the electric steering, or ABS
DSC I believe no one has ever got worki as it takes steering angle and wheel speed and controls throttle which isn't possible when using a standalone.
I do have all the info for each ID of these warning lights, I figure since you already are spoofing the dash, surely it's easy to add these quick additions to remove warning lights for deleted systems?
ID 212 is abs, dsc off, traction control warning and brake warning, minimum 0.5 sec timing.
ID 420 is temp, oil pressure gauge, coolent level, battery (alternator), oil warning and check engine light, minimum 5 second timing.
ID 201 is Speed (Max 300.00 Km/h, 186mph [9C 40] and RPM (Max 16382 [FF FE], although scale goes non-linear after 10k), minimum 0.5 sec timing.
Jeff
ABS
Jeff
