DI Injectors with Emu ?
Posted: Sun Jun 25, 2017 1:41 pm
Are there any Plans to Controll DI Injectors like TFSI or other with EMU or any Controllers for it Availible ??
Technical support for Ecumaster products
https://www.ecumaster.com/forum/
Thats great. What about DSG Control ?jt-performance wrote:Later this year there will be a pro ECU ready for DI
Its not just about "control" you need real comunication between ECU and Gearbox controler. Because if you shift, you need serious torq reduction to allow the shift without destroying the gearbox immediatly.golf_g_turbo wrote:Thats great. What about DSG Control ?jt-performance wrote:Later this year there will be a pro ECU ready for DI
There are more then the Comunication between the Ecus and Torque Reductions for Running a DSG. ESP,ABS Signals etc...... I build my Racecar with DSG.Karel wrote:Its not just about "control" you need real comunication between ECU and Gearbox controler. Because if you shift, you need serious torq reduction to allow the shift without destroying the gearbox immediatly.golf_g_turbo wrote:Thats great. What about DSG Control ?jt-performance wrote:Later this year there will be a pro ECU ready for DI
