Can you use an EMU base calibration file on the Black? If not can someone convert the 7MGTE EMU file to the Black version?
Thanks,
Scott
EMU Base map on EMU Black
Re: EMU Base map on EMU Black
You can use the setup, so just overwrite all the trigger setting, firing order, etc and you will be fine. Just make it...
On EMUblack you can import EMU projects.
Go to File/ Import EMU Project.
Wisetechscott
Thanks Scooter thats the info i was looking for
