We are running 2011 5.7 litre gen3 hemi with EMU black ecu. And we have difficulties with alternator, it charges 17 volt. No mater what pwm values/alternator parameters you change. Alternator has connector with two pins, first is connected to 12v and second to a "aux" pin in ecu.
Any help?
Alternator issue
Re: Alternator issue
All the issues should be solved as early as possible so that the students could learn more.The coupon assistance is needed in order to discover the actual strategy.
