hey, can anyone give me some advice
i cant find a manual for the emu black so have been lookinf at the emu manual
i see the emu black needs a battery +12v and switched +12v
my question is does the battery +12v need to be constantly live or can i run that off my pmu?
i was thinking of running the battery +12v off the pmu and then switched +12v off the ignition switch
or do i need to wire the battery +12v to battery and switched live off the pmu?
also what guage of wire is suggested for these 2 power cables?
thanks
power supply
Re: power supply
anyone?
this is holding me up finishing my loom as I don't want to do it wrong or use to small a wire
Re: power supply
Constant 12V is constant 12V all the time.
Switched 12V turns the EMU on, and should be from Ignition switch (key)
