i need some help to get a proper idle.
I use DBW and the parts work well i think, 0-100% with ignition on.
But when idling, the throttle min 5-6% open and idle is to high. About 1150, target is 900.
When i say: idle off if TPS over 6% and i give lighty open throttle, then you see in the Tune Display: 3-4-5%
I play around with PID or Voltage "position min" or.. or.. do not find my fault
Ignition must be -15° for the target idle, but... mouch to late.
What do you mean i should do?
