Ignition event, injector phase (S50B32)
Posted: Sun Nov 18, 2018 11:56 pm
Morning all, just need some further clarification on ignition events. I've done some searching etc but for this instance i assume i'm missing something fairly simple that hasn't occurred to me for whatever reason.
The engine runs, albeit EXTREMELY rich *all* the time - Its running AlphaN with the right injector settings for 5bar/deadtimes (0280155868) etc, however i can adjust injectors to 850cc to reduce PW and it will go from AFR 9:1 to 11:1, the VE is set to 50 in the idle range (i can lower it to 20ish to bring it in as well). Its a 60-2 trigger running at 5tooth +54degrees, sync'd with exh cam 6+1 and confirmed at 10degrees (locked) with timing light.
In order to run, i have to set the ignition (153624) offset to 3, whilst my injection is set to ignition event 153624. I've played with changing injection up 2 events and setting it 'start/end inj cycle' to 120+54 with no change. I can set to 0 offset and it will kick once but thats about it.
Why do i have to set the ignition offset to 3 when it should be at 0 since trigger is set at #1 TDC?
Unfortunately i'm at work so no logs to attach at the moment
Cheers
Cheers
