2jzgte to BLACK pin out
Support for EMU BLACK device
Jostar
Post by Jostar » Tue Nov 22, 2016 5:51 pm
I am very interested in the BLACK, Do you guys have a pin out for the 2jzgte to black available?
WHPZach
Re: 2jzgte to BLACK pin out
Post by WHPZach » Tue Nov 22, 2016 6:11 pm
It would be the exact same channel assignments as the EMU, with the exception of the added constant 12V wire. That and if the signal from the A/C amp is a low side trigger, you can wire that to one of the switch inputs instead of having to use an analog input with a pullup.
jacool
Post by jacool » Wed Nov 23, 2016 5:02 pm
WHPZach wrote:It would be the exact same channel assignments as the EMU, with the exception of the added constant 12V wire. That and if the signal from the A/C amp is a low side trigger, you can wire that to one of the switch inputs instead of having to use an analog input with a pullup.
can 'constant 12V' channel be used as a Vref for a sensor instead of 5V?
0martin0
Post by 0martin0 » Wed Nov 23, 2016 10:48 pm
constant 12volt is from batery to ecu its mentioned to power ecu if engine is not running to avoid uncontrolled status of outputs during processor boot-up.
NOT to feed sensors or whatever else
jacool
Post by jacool » Thu Nov 24, 2016 1:54 pm
0martin0 wrote:constant 12volt is from batery to ecu its mentioned to power ecu if engine is not running to avoid uncontrolled status of outputs during processor boot-up.
thanks
