installing the pmu
adzer
installing the pmu
Post by adzer » Sun Jan 21, 2018 1:36 am
hey, got a couple questions about installing the pmu
first question is I see you can combine 2 outputs for a bigger amp output, setting it up in the software is straight forward but what I cant find is how you wire that up to your output?
for example I want to wire up a fan, do I only need to connect the fan to 1 of the 2 outputs I combined on the pmu or do i need to wire it into both the output pins?
second question is, can I wire multiple items upto 1 output on the pmu?
for example could I wire up my haldex controller & digital dash off 1 output? i was presuming this would be ok and would work fine but just wanted to make sure?
I'm sure ill have more questions :roll:
thokes82
Re: installing the pmu
Post by thokes82 » Sun Jan 21, 2018 7:18 pm
1st answer: connect both.
2nd answer: you can. You will not have your haldex controller and dash monitored individually and cannot observe if you have undercurrent or overcurrent. It is like connecting two devices to one fuse. But yes, it works.
