PMU to Motec M1 CAN stream
FIS
Post by FIS » Mon Jan 28, 2019 7:11 pm
I am doing PMU CAN communication setting with M1 Motec. I found information on M1 CAN stream to PDM from its help file. Is this can be used or should use ADU to Motec M1 CAN stream.
I also want to transmit PMU's I/O status
Appreciate your help
jgm
Re: PMU to Motec M1 CAN stream
Post by jgm » Mon Jan 28, 2019 7:53 pm
What kind of information do you want to send from PMU to M1 exactly?
Analog state or analog voltage?
Output state or output current/voltage?
jgm
Post by jgm » Mon Jan 28, 2019 8:01 pm
The Motec PDM CAN stream is available in the document called "Motec PDM User Manual.pdf".
The stream needs to be emulated.
http://www.precisionautoresearch.com/ec ... l%20A5.pdf
FIS
Post by FIS » Tue Jan 29, 2019 7:21 am
I want to send the followings
to AIM MXG
- Analog voltage and state
- Keyboard state
- Output voltage
to M1
fuel pump fault
radiator fan output
Attached is setting for receive from M1 please correct me if wrong
Thank you
can test.pmu
(85.35KiB)Downloaded 79 times
jgm
Post by jgm » Tue Jan 29, 2019 1:51 pm
I've added export of these fuelPump and radiatorFan outputs status to M1.
The meaning of the status in Ecumaster PMU is as follows:
0 - off
1 - on
2 - undercurrent
3 - overcurrent
7 - thermalShutdown
In the Motec PDM the meaning of the status is as follows:
0 - off
1 - on
2 - overcurrent
4 - fault (similar to PMU's thermalShutdown)
I'm using for each output the following formula:
errorCode=lookup3(pmu_o_status-2, [0,2,4])
pdm_status = choose(pmu_o_active, 1, errorCode)
Exporting is done to BaseID+4 (0x504)
can_test_w_export.pmu
(93.7KiB)Downloaded 78 times
jgm
Post by jgm » Tue Jan 29, 2019 1:55 pm
(continued)
Two frames need to be sent with different CompoundIndex (bit shift is 6)
- CompoundIndex=0: value 0 at byte0 (it's 0<<6 in C notation)
- CompoundIndex=1: value 64 (0x40) at byte0 (it's 1<<6 in C notation)
jgm
Post by jgm » Tue Jan 29, 2019 1:57 pm
For AIM MXG I recommend to enable PMU Standard Stream at 0x668 and read it directly in the AIM MXG.
FIS
Post by FIS » Tue Jan 29, 2019 4:20 pm
Thank you very much. I will test and learn it
FIS
Post by FIS » Sun Feb 03, 2019 3:51 pm
I test the setting you gave on bench it was so fun :D . Emulate the PMU's output and M1 will detect when fuel pump or fan fault.
Also to receive message from M1 (to 'PDM') I set the ID 0x118 on PMU, it was quite straight forward
question
1. in CANBus export "x_PDMtoM1_ID+4_CI=1", can you explain meaning of value 64 in channel 0
2. Please check the setting ID 0x119 in PMU CANbus Inputs
can_test_w_export rev2.pmu
(111.31KiB)Downloaded 79 times
FIS
Post by FIS » Sat Feb 09, 2019 6:44 am
question
Done by importing the Motec CANX file :oops:
jgm
Post by jgm » Thu Feb 21, 2019 9:54 pm
question
This Motec stream is 2bit Compound CAN stream. It means that 2 most significant bits (0x80 and 0x40) of the Byte0 are used to identify what the sub-frame index is. 64 means the CompundID=1, like on the screenshot from the Motec documentation I've posted. It's 1 << 6 in C notation (<< denote ShiftLeft operator).
