CAN switch board
FIS
CAN switch board
Post by FIS » Thu Feb 28, 2019 6:14 am
I use CAN switch board for my steer switches using simple switch mask. I wonder what is SW parameter and how it works. I couldn't find in manual.
Thank you
jgm
Re: CAN switch board
Post by jgm » Thu Feb 28, 2019 12:12 pm
There is .CANX file for the Switchboard included in the PMU Client (attached a copy).
Please configure the Switchboard using jumpers on the pcbboard for ID2 (the ID will be 0x666).
All 8 switches are switches to ground (Active Low in PMU terminology).
canSwBoard_ID666.zip
(498Bytes)Downloaded 38 times
FIS
Post by FIS » Thu Feb 28, 2019 2:29 pm
Thank you for reply,
What is the meaning of parameter SW#1-SW#7 on ID 0X335?
jgm
Post by jgm » Thu Feb 28, 2019 3:05 pm
It's the copy of the information from the Switchmask. Some ECU does not handle bit extraction.
It's 0 (zero) or 1 (one) passed as the whole bytes in the CAN stream.
Consider using ID2 at 0x666. The support is integrated into EMU BLACK, maybe you can use it in the future.
FIS
Post by FIS » Thu Feb 28, 2019 3:24 pm
I got it. Thank you !
