Hello guys,
is it possible to run a staged fuel pump setup with the DET3 with it´s own boost controller function?
-fuel pump #1 is running all the time
-fuel pump #2 kicks in @ 14 PSI etc.
Like: If boost is XX PSI - > then send a signal to fuel pump
Is this possible to use a output signal at a specific boost level?
Thanks for your help.
bye
Alex
Staged fuel pumps
Re: Staged fuel pumps
Yes, you can use parametric output and control second pump relay in function of RPM / Boost
That´s great.
Damn this piggyback has some great features.
