I have found something strange. When i open my project with ecu on my laptop i have TPS sample rate and idle DC corr table.
When i connect to ECU in the car with the same laptop ,i have none of the two. They are not in the list ????
Soft update from the ecu necessary ?
Patrick
Strange
Re: Strange
Yes of course, if you use different firmware you have to update the EMU or downgrade your laptop. But you have to use the same versions on both.
Re: Strange
I thought so.
Anybody has procedure to upgrade the ecu ? ( and file ? )
Grts
Patrick
Grts
Patrick
Re: Strange
1) disconnect injectors and coils
2) Open EMU software, click on "File" menu and select "Upgrade firmware"
3) wait until finished
4) turn off ignition
5) connect coils and injectors
6) start
6) start
Re: Strange
Do i have to be connected to internet or will the ecu take the update from the software on the laptop ?
On the laptop is the latest version.
Re: Strange
on laptop is latest version...
- Kisielisodd
- ECUMASTER TEAM
Re: Strange
lastest versions are at www.ecumaster.com/tv
Re: Strange
Just to clarify firmware is embedded in software so once you have a new software version firmware is there
