2jzgte vvti help
DET3 technical support
kpersaud90
2jzgte vvti help
Post by kpersaud90 » Sun Apr 03, 2016 8:21 pm
hi im new to the whole det3 how should i wire it to my ecu and will i need to use a hks fcd for fuel cut dose any one have any diagram or any info any littile bit will help thank you
kpersaud90
Re: 2jzgte vvti help
Post by kpersaud90 » Mon Apr 04, 2016 1:39 am
Any one
WHPZach
Post by WHPZach » Mon Apr 04, 2016 9:46 pm
You'll need to intercept the MAF wire (to an analog input on the DET3, then analog output to your stock ecu) and intercept the crankshaft position sensor (NE on toyota wiring diagrams). I don't have a diagram handy, but might be able to put one together this week.
You will not need an FCD, you can clamp the output voltage with the DET3.
kpersaud90
Post by kpersaud90 » Tue Apr 05, 2016 2:15 am
Please if you can put a diagram together i would so appreciate it its a jzs161 aristo 2jzgte vvti im really confused because the car has a factory map and maf so please help if you can thank you
WHPZach
Post by WHPZach » Fri Apr 08, 2016 7:47 pm
kpersaud90 wrote:Please if you can put a diagram together i would so appreciate it its a jzs161 aristo 2jzgte vvti im really confused because the car has a factory map and maf so please help if you can thank you
The MAF sensor is the important one. Cut that wire. Wire from MAF to analog input, wire from analog output to the stock ecu.
StanleyOn
2jzgte vvti help
Post by StanleyOn » Fri May 06, 2016 3:25 pm
Thank you I found this motor quite easy to tune although the final was not done by me.
I am looking forward to a ride with the VVTI working
hello
450franko
Post by 450franko » Sun May 08, 2016 8:47 pm
the vvti have the 30-2 trigger weel the ignition mode is retard-advance miltitooth signal the ignition input type is vr sensor adaptive thredhold maximum rpm 7000 num signal per 720 is 24
450franko
Post by 450franko » Sun May 08, 2016 8:59 pm
setup table ----- fuel table analog #1----- analog #1-------disable------disable----------------ignition table-------analog#1-------analog#3--------------analog#4--------------------pwm table #!--analog#1---analog#3 analog#4 pwm table #2 is the same
450franko
Post by 450franko » Sun May 08, 2016 9:14 pm
maf sensor----b2-10-vg gos to analog in#1 (13)---------analog out (17) gos to map sensor---b2-9-pim-------crank sensor b1-23--net gos to ignition in(9)--------------bipolar ign out(5) gos to crank sensor ecu b1-23-net--------1is 12 v--------11 is ground is this correct
