There is new software 1.163 with injection angle control.
In most cases the End of injection should be selected.
It is important to properly set up injectors phase first.
If your ignition outputs table looks like this: (4 cyl 1-3-4-2) you need to setup the injection phase as follow:
It is important that ignition output offset is automatically applied in the software so you do not need to transpose anything
Due to injection angle control you can improve your fuel consumption in low / med load and improve your idle quality, especially when you use big injectors.
The easiest way to determine the proper injection angle is to keep engine in steady state for given load/ RPM and modify injection angle table to get the richest possible mixture.
You can download the software from:
http://www.ecumaster.com/tv
I'm looking forward for your feedback
