Ignition on, injectors hold open
Sc3002
Post by Sc3002 » Sun Apr 10, 2016 5:33 pm
I changed from Batch fire to sequential fire. Changed the settings on the emu and assigned the injectors etc. Now I have voltage to all injectors with key on holding them open causing immediate flooding. Did I miss something? Is there a setting or a box needing unchecked?
ihiryu
Re: Ignition on, injectors hold open
Post by ihiryu » Mon Apr 11, 2016 6:00 pm
How did you wire it up? I haven't done a batch to sequential install, just went straight to sequential.
You should have power on one side of the injectors, and the other pin should ground out from the EMU.
Do you have Hi or Lo Z injectors?
