i have an rb25 det engine with 36-1 trigger wheel.
when i try to start the engine i can se my rpm is about 140.
my ignition angle is 10 degres.
but i have no sync, no spark, and no injector reaction.
i am using VAG coils.
coils type: coils with built in amplifier.
sensor type: vr sensor
trigger type: with one missing tooth
trigger edge: falling
num teeth: 36
first trigger tooth: 3
trigger angle: 80
hope someone can help me.
no sync, no spark
Re: no sync, no spark
Please post your map and a scope.
I think it will be enough to change your settings to rising on primary trigger.
oliverthomsen
i have a picture that shows turning the engine.
- thumbnail_IMG_2305.jpg (31.65KiB)Viewed 3544 times
Sorry can't see.
Go in under primary trigger and enable scope, then go to log ----- > scope -----> Crank it and press the arrow "get scope data" whilst cranking.
oliverthomsen
Problem solved.
The Sekundery trigger type has to stay on "do not use"
Thanks so much for helping.
that will only work in waste spark configuration now
