2 rotor engine.
Steffenrx7
2 rotor engine.
Post by Steffenrx7 » Wed Apr 20, 2016 7:28 pm
Does the EMU support rotary engines, some say noe and some say yes??
Re: 2 rotor engine.
Post by PSI-Motor » Wed Apr 20, 2016 11:01 pm
Hello.
Sorry but it does not.
Re: 2 rotor engine.
Post by RHD » Thu Apr 21, 2016 3:41 am
could it not be done by entering it as a 4/6cyl engine and using ignition offsets??
Danansmith
Re: 2 rotor engine.
Post by Danansmith » Thu Apr 21, 2016 10:17 am
I also want to know the real results. Hoping to find the best solution, we look forward to your sharing. Thank you.
_______________________________________________________________________________________________________
popular bubble football:Bubble soccer
Re: 2 rotor engine.
Post by Karel » Thu Apr 21, 2016 11:45 am
I was thinking about it ....
you can use 2 rotor like 4piston engine .... you will just use two coils like leading and second two like trailing. It has just one disadvantage, you will end with fixed distace between them, but it is possible. But you will need to change the timing Wheel on the crank, so you can fool the EMU that it has moved 3time arround and it will also think it is moving 3x faster then it actually does.....
So basicly it can be done, but with some issues.
Other idea is use it like 12 cilinder but spark it like
1event ... 1 cil leading
2event ... 1 cil trailing (with offset)
3event ... 2 cil leading
4event ... 2 cil trailing (with offset)
5event ... 1 cil leading
6event ... 1 cil trailing (with offset)
7event ... 2 cil leading
8event ... 2 cil trailing (with offset)
9event ... 1 cil leading
10event ... 1 cil trailing (with offset)
11event ... 2 cil leading
12event ... 2 cil trailing (with offset)
it will remain the RPMs correct and there will be no need to change the crank Wheel etc....
You have ideas from me so lets try this......... or what do you think Jadzwin or RHD ?
