lauch control, flat shit, rolling AL
aaronRX72JZ
i want to use both, and im planning on wiring them both to the clutch switch. Can i use 1 input for both functions without a MUX switch setup? Maybe if is set the VSS speed and RPM parameters different for both functions? and also i want to hook my Rolling AL to a push button on my shifter but i dont have a 5V source anywhere close to wire in a analog switch. does it have to be 5V or can it be 12V?
aaronRX72JZ
Re: lauch control, flat shit, rolling AL
never mind the first questions. i found that there is a option for launch control to be always active so i dont have to with in a switch for that. and i plan on removing the harness and plum a wire from B23 to the cabin for my switches, but in the wiring diagram for the switches i found it just says ground but since it is +5V supply im guessing it means to use B18 as ground?
