Hello I just wanted to know exactly hour to setup my vss & traction control? My setup is 2jzgte with a cd009 in 350z.
Basically I know where the vss wire is, do I need to tap that then pin into my emu? Does the traction control need a wire tapped into all 4abs sensors?
VSS & traction control setup?
Re: VSS & traction control setup?
The EMU only has one VSS input, so it needs to see the signal from the transmission.nolagg wrote:Hello I just wanted to know exactly hour to setup my vss & traction control? My setup is 2jzgte with a cd009 in 350z.
WHPZach wrote:The EMU only has one VSS input, so it needs to see the signal from the transmission.nolagg wrote:Hello I just wanted to know exactly hour to setup my vss & traction control? My setup is 2jzgte with a cd009 in 350z.
Still doesn't assetrt my question,I want to know exactly what I have to do in order to get ire with my setup.
The signal wire from the VSS needs to go to the VSS input channel on the EMU.nolagg wrote:WHPZach wrote:The EMU only has one VSS input, so it needs to see the signal from the transmission.nolagg wrote:Hello I just wanted to know exactly hour to setup my vss & traction control? My setup is 2jzgte with a cd009 in 350z.
Ok well since it is a can bus does that matter?I know in the 350z, the vss signal wire tune up to the can bus type box in my climate control.would I just tap off of that? Or do you know that the cd009 350z trans has a specific sensor?
need a wire tapped into all 4abs sensors?[/quote]
The EMU only has one VSS input, so it needs to see the signal from the transmission.[/quote]
Still doesn't assetrt my question,I want to know exactly what I have to do in order to get ire with my setup.[/quote]
The signal wire from the VSS needs to go to the VSS input channel on the EMU.[/quote]
Yes connect the wire from the Transmision im the VSS from the Emu
But you Must select in the Option "calculated"
The wires run into the can bus system though I believe i the cabin.there's 2vss wires one with a4 puller the other with an8.
Does it matter
It shouldn't matter.
