nyl
astra vxr
Post
by astra vxr » Sun Dec 07, 2014 12:25 am
pin 1 signal
pin 2 signal
pin 3 12v
fireing order
plug
1 4
3 2
dwell setings are around 3.5ms ( well thats we used on the megasquirt )
carnt help with the config as of yet as im a new user and comeing from megasquirt its a bit different set out
but if you want the tooth wheel settings i have them
nyl
Post
by nyl » Sun Dec 07, 2014 7:41 am
and the 4th pin?
edit: nvm i see it's not connected :p
anyway, so:
pin 1: 1 - 4
pin 2: 2 - 3
- GWRA4 SBD COIL PIN OUTS COLOUR.pdf
- (60.61KiB)Downloaded 133 times
Maciekx - Posts:22
Post
by Maciekx » Sun Dec 07, 2014 11:54 am
Ignition coil from x20xev with 4 pins has signals on 1 & 2 pins and +12v at ignition on 3 & 4 pin. Newer x20xev ( simtec 56.5) has 3 wire connector and 3 pin ignition coil.
astra vxr
Post
by astra vxr » Sun Dec 07, 2014 12:50 pm
nyl wrote:and the 4th pin?
anyway, so:
pin 1: 1 - 4
pin 2: 2 - 3
yes correct been useing one of these coils for over 5 years like this with out any trouble
- Site Admin
Post
by Jadzwin » Sun Dec 07, 2014 4:14 pm
I've just look at X20XEV schematic and it seems that 3 and 4 are connected to +12V.
Probably both terminals are internally connected, so that is the reason it works with 4 terminal unconnected.
astra vxr
Post
by astra vxr » Sun Dec 07, 2014 4:48 pm
Jadzwin wrote:I've just look at X20XEV schematic and it seems that 3 and 4 are connected to +12V.
thats correct vauxhall only used pin 3 ( on the x20xev ) and didnt bother with pin 4 and we have been running them for years that way with out and troubles even with big boost even autodata doesnt list pin 4
