Quick question regarding the CAN connection.
I have the EMU with the CAN module built in.
Does this have the 120ohm termination resistor built in or should I hard wire in the harness?
Thanks in advance
CAN Bus terminating resistor
Re: CAN Bus terminating resistor
i dont think any emu has the can module built in does it?
the CAN adapter is usually an additional box that plugs into the EXT port, and yes you usually need to place the resistor at the end of the CAN wires
heres a really nice picture from Motec that shows everything very clearly
Yes you need to add it
Thanks gregpe
RHD, EMU is available with the can module built in.
