BMW E34 2800 Turbo- need basic map
aspar
Post by aspar » Fri Jun 10, 2016 12:30 pm
Dear colleagues, my project is BMW E34 2800 Turbo.
I have installed EMU -ECU master. I have connected all needed cable work according to directions ( specifications). I have the base configuration installed. At this stage the engine starts, runs for a 30-40 sec. and shuts off. As i am monitoring actual values, it reads RPM, coolant temperature, air intake, TPS, MAP, it is all correct. The main rely and pump rely work correctly as well. The Crank shaft pully is 60-2 tooth, the cam shaft is one vanus. ori. ECU is bosch 0 261 200 413
I can not attach a file and some pictures here, but can send it directly if anyone is willing to help out.
I need a base map to upload and have the engine start and run.
Thank you in advance and looking forward to all your help and suggestions
