low resistor injectors
driftkids
Post by driftkids » Sat Jun 25, 2016 7:51 pm
hi, about to connect precision low ohm resister injectors, and in the manual it says i need 4,7 ohm resistors. the grounds of the resistors is connected to a common ground, and before this all the grounds of the injectors goes together and goes through a 240 ohm / 2 W resistor. is this enough or must i remove this one and use separate? I'm using the original bmw m50b25 injector connections, and it is inside this one the common ground with this resistor is found
Re: low resistor injectors
Post by Karel » Sun Jun 26, 2016 12:44 pm
everything wrong Mate!
you need to connect all injector to +12Volt and the other side trough cca 4 Ohm resistor to the EMU output.
