Knock sensor setup for Nissan RB26DETT
R-tune
Post by R-tune » Tue Jul 05, 2016 7:15 pm
Currently I'm working on my calibration for the RB26DETT engine in my Skyline R33 GTR.
This engine has 2 knock sensors, one for each "bank", so cylinders 1-3 are sensor 1 and cylinders 4-6 are sensor 2.
I'm using an "output offset" of 1 in the ignition outputs configuration.
Is the sensor configuration I used correct?
Or do I need to change the correlation of knock sensors to ignition events because of the output offset?
Thanks!
EDIT: Can't attach any picture, because the quota has been reached?!
derOJ
Re: Knock sensor setup for Nissan RB26DETT
Post by derOJ » Wed Jul 06, 2016 7:24 am
Maybe you have to resize your Picture, so it isn't so big (Megabyte)
Hallo vom Niederrhein :)
Welshman
Post by Welshman » Wed Jul 06, 2016 12:31 pm
use a image hosting service like https://postimage.org/
R-tune
Post by R-tune » Sun Jul 10, 2016 6:02 pm
This is the current config.
It would be very helpful to know, whether the output offset in ignition outputs is important for knock sensors as well?
redmkiv
Post by redmkiv » Sun Jul 10, 2016 8:54 pm
Knock Frequence is wrong
Lock Here:
http://www.ecumaster.com/Help/EN/Knocks ... eters.html
Thomas
PS A Customer is runing the EMU with a Garett Turbo in a Skyline at the Time around with 1.6 Bar
ihiryu
Post by ihiryu » Sun Jul 10, 2016 11:42 pm
R-tune wrote:This is the current config.
No. Ignition offset only changes when they fire. Basically 123456, is with an offset of 0. Then if you change the offset to 1, it'll fire 234561
R-tune
Post by R-tune » Mon Jul 11, 2016 10:13 pm
Hmm, you are probably right, but take a look at this posting from Jadzwin.
He proposes to change the knock sensor order because of the output offset. So which way is the correct one??
viewtopic.php?f=19&t=24&hilit=integrator&start=20#p1891
