DET3 w pytaniach i odpowiedzach
qpmz - Posts:1
Post
by qpmz » Fri Jun 17, 2016 10:23 pm
Witam,
dołączam się do pytania. Zaznaczam, że g13bb ma tylko czujnik położenia wałka rozrządu.
Były też z położnikiem wału + wałka rozrządu, ale to egzotyka. Wtedy można je odpalić na subaru 30-2-2-2
@onyx czym dmuchasz do tego 1.3?
onyx - Posts:4
Post
by onyx » Sat Jun 18, 2016 12:55 am
Odzew ze strony możnych jak na razie żaden... i chyba pozostanie w głębokim poważaniu.
Mam zamiar wrzucić M45, ale kwestia braku możliwości strojenia utrzymuje stan stagnacji...
putani - Posts:23
Post
by putani » Sat Jun 18, 2016 3:16 pm
DET 3 Ignition Control for 2 Ignition modules in a Suzuki
Hi All,
I have an issue with the wiring connections on the IGNITION MODULES on a Suzuki which has a wasted spark type ignition system.
Now I am little confused looking at the Ignition wiring on the DET3 side and also on the OEM ECU side.
I would like to know the below mentioned which will help me wire up the DET3 and solve the wiring issues
1. IGNITION IN - do i have to connect wire directly tapping the sensor signal voltage???
2.IGNITION OUT - there are three output pins which one should i coneect the IGN OUT wires from DET to the ECU
I request somebody would really answer my issues and help me rig up the DET3 on my car
LIVE LIFE FORCED INDUCTION
onyx - Posts:4
Post
by onyx » Sun Jun 19, 2016 12:32 am
Since now there is no trigger in DET3, that would work with cam sensor.
Probably subaru type of ignition trigger would work with crank signal and crank wheel from Baleno/Wagon r+.
putani - Posts:23
Post
by putani » Sat Jul 23, 2016 11:22 pm
onyx wrote:Since now there is no trigger in DET3, that would work with cam sensor.
This version is without Dizzy and it comes with CAM and CRANK sensor
below image is the reference of the coils
Is it possible to advance and retard timing using DET3....
onyx - Posts:4
Post
by onyx » Sun Jul 31, 2016 12:24 pm
As I mention above, there is no version of propper ignition trigger that will works with that engine (for sure if signal is taken from camshaft sensor).
The crankshaft trigger in Suzuki looks the same as Subaru 36-2-2-2 and if I look into manual right, it's not supported.
It would be realy nice if Jadzwin put firmware update with trigger of camshaft - some of Suzuki owners are waiting for this
