Using a Greddy Solenoid for Boost Control
ren
Re: Using a Greddy Solenoid for Boost Control
Post by ren » Sun Aug 07, 2016 11:10 pm
If it's the one from the profec-b or profec-b spec 2, then as per the manual.
Welshman
Post by Welshman » Mon Aug 08, 2016 2:33 pm
i use the greddy spec 2 valve , wired as per manual , atm im running 2.3 bar , dropping to 2.1 by 8k in closed loop
ren
Post by ren » Wed Aug 10, 2016 10:31 pm
Stout. What engine/turbo is that on?
Welshman
Post by Welshman » Thu Aug 11, 2016 5:50 pm
3sgte pte 6266 gen 2
just dropped a piston though , would of been ok if heat compensations were set right HOT day , drag strip and big cue not so good 10.55 though .
