C20LET with Audi R8 ignition coils, proper configuration?
Hey does anyone here run c20let with Audi R8 ignition coils? I need the ignition config file
Re: C20LET with Audi R8 ignition coils, proper configuration
I think these are Logic level type of coils two grounds, +12v and signal
Thats correct. Dwell time around 2.2-2.5 ms att 14v
Hello
That is dwell for the red Audi ignition coil 06F 905 9115 A,B,C,D,F
8V => 3,3ms 10V=> 2,8ms 12V => 2,4ms 14V => 2,2ms 16V => 1,5ms
and pins
1: Power supply terminal 15 (+6 to + 16V) 2: mass terminal 31 3: control signal 5V (2.8V turn-on; off threshold 2.3V) 4: mass for control signal
- Coil energy 55mJ - secondary voltage 28 - 35kV - primary current (15A), rise time at 14V => 2,4ms (20 ° C) Permissible temperature range during operation (coil): -40 to +150 ° C.
Regards
and pins
Regards
Thanks for the info, i'm using 06e-905-115-e
Is the samenyl wrote:Thanks for the info, i'm using 06e-905-115-e
How are you coils connected (cylinder to ignition output )
Yup, both coils and injectors, cyl 1 - output 1, cyl 2 - output 2....
So your ignition event table should look like this:
Ign even 1 - Output 1
Ign even 2 - Output 3
Ign even 3 - Output 4
Ign even 4 - Output 2
Or if you start the engine only with crank sensor (wasted spark)
Ign even 1 - Output 1 + 4
Ign even 2 - Output 3 + 2
Ign even 3 - Output 1 + 4
Ign even 4 - Output 3 + 2
Can you give me an complete dwell time setup for the RED 115E Coils
for the complete Volt Range?
It is for an M50B25 with the R8 Coils.
thanks a lot
best ragarts,
tim
thanks a lot
best ragarts,
tim
