rb20/25 cas sensor wiring/ set up
bart
Post by bart » Sat Dec 27, 2014 5:45 pm
can anyone forward me wiring examples of rb/sr wiring for emu, also trigger wheel set up
and tps for twin plug would be nice aswell
bart
Re: rb20/25 cas sensor wiring/ set up
Post by bart » Sat Dec 27, 2014 6:03 pm
tps sorted, anyone can help with cas sensor??
Post by Jadzwin » Mon Dec 29, 2014 1:18 pm
Here is a wiring table for RB25DET and the map that allows to start the engine (RB25)
mapa_rb25det.emu
RB25 base map
(45.46KiB)Downloaded 295 times
RB25DET.pdf
Connection table
(72.31KiB)Downloaded 289 times
Eisen
Post by Eisen » Wed Jan 07, 2015 1:24 pm
Hi is it possible to run a Rb25 det neo6 from an R34GTT with this basemap too? Or are there any problems because of the varible camshaft?
Outclass-Performance
Post by Outclass-Performance » Fri Dec 04, 2015 9:15 am
Yes
rb25det neo starting with this map ;-)
http://www.outclass-performance.com/
Team Outclass
Performance
louie588279
Post by louie588279 » Sat Apr 22, 2017 7:19 am
Jadzwin wrote:Hi!
I used this base map, for Rb25det s1 but didn't fire up, Need help on getting to start with base map, it starts up fine with the stcock ecu and safc just not with the ecu standalone with base map, help please
Post by RHD » Sat Apr 22, 2017 9:17 am
post up a log of some cranking and the actual map from the ecu
