I'm trying to do 2 things, with my car:
1) Ignition modification
2) MAF to MAP Conversion
Unfortunately I'm having issues and need help
Ignition
I wanted to control ignition module, but according to MX-5 diagram, there are 2 coils and both controlled by ECU (in your manual, you write that I could destroy your unit, and control only one coil) -- correct me please if I'm wrong.
MX-5 NB Diagrams (page 8-10)
Settings: Retard / Advance 60-2 and Hall effect
So I wanted to modify output from Hall sensor (with pull-up resistor). But when I cut hall's wire and connect Ignition In and Ignition Out, engine won't start
I even tried to connect it back(car started) and than connected only Ignition In to get at least RPM to piggiback, it still won't start
I have cut MAF signal cable, connected according to your schema, but car barely starts. Piggyback input/output show 5V (max output) and it results in incredible rich mixture. When I disconnected mazda ECU, output from MAF shows actually 7V, but when connected back to ECU, there is only 1.25V when engine is not working(that's correct).
Looks like I have conencted something fundamentally wrong.
Thx for any help
and this is the pinout for 1.8NB:
