AEM Failsafe Guage Scales Configuration
DET3 technical support
twister814
Post by twister814 » Tue Nov 08, 2016 12:23 am
I cannot find a Scale to give the Exact Readings My AEM Failsafe guage shows. My Aem UEGO guage does show the same Readings on the DET3. Is there an update or Option to help me use the AEM Failsafe guage on the DET3 ? :?: Please HELP
twister814
Re: AEM Failsafe Guage Scales Configuration
Post by twister814 » Tue Nov 08, 2016 12:36 am
I'm not finding a scales configuration for My AEM Failsafe o2 Gauge. any Information for this one ?
The DET3 Reads different than the gauge on any of scales offered form the unit
ihiryu
Post by ihiryu » Tue Nov 08, 2016 1:10 am
Analog scales configuration.
Read in the AEM manual to get the values
twister814
Post by twister814 » Wed Nov 09, 2016 2:48 pm
Thanks this gives me an idea where to start from with my beginner level of understanding. Hopefully this hashes out. The Newer failsafe guage offers several features as an advantage.
The Det3 has several wideband options that didn't work.
twister814
Post by twister814 » Fri Nov 11, 2016 2:48 am
Has anyone used a Aem falsafe wideband O2 guage on the Det3 piggy back successfully. Where the unit shows the same reading as the guage ?
twister814
Post by twister814 » Sat Nov 12, 2016 7:48 pm
Can these values be entered so the Det3 reads the same ?
Doable
Post by Doable » Tue Nov 15, 2016 9:44 am
Have you tried something like this?
wideBandO2SensorAEMFailsafe.txt
(402Bytes)Downloaded 165 times
To use it, change its extension to ".def".
twister814
Post by twister814 » Tue Nov 15, 2016 6:15 pm
This will be a first for me.
Thanks alot in advance
Doable wrote:Have you tried something like this?
twister814
Post by twister814 » Wed Nov 16, 2016 5:08 pm
I have the AEM Fail-Safe scale on analog #3 now. Just Need to check it.
twister814
Post by twister814 » Wed Nov 16, 2016 11:44 pm
I must have done something wrong. This didn't do anything.
twister814
Post by twister814 » Thu Nov 17, 2016 12:11 am
The yellow pad lock must be why it's not working. How do I solve this I been trying so hard. I'm sure it a simple solution. Help
twister814
Post by twister814 » Thu Nov 17, 2016 12:29 am
Doable,
i must say i dont know how to change the extention to ".def"
any help on that id aprciate. I have been trying since you posted......lol
twister814
Post by twister814 » Fri Nov 18, 2016 2:31 am
Thanks Doable, It seems you offer a easy suggestion it just doesn't work for some reason. By changing the extention to ."def"
Thanks again
twister814
Post by twister814 » Fri Nov 18, 2016 2:39 am
Anyone know how to get the Det3 to read the same as on my AEM falesafe wideband guage ?
The Det3 doesnt have a Scale to match the Guage readings or they not reading the same numbers... Any Answers Please
twister814
Post by twister814 » Sun Nov 20, 2016 3:49 pm
Is this something ECU Master Tech's Must Fix ???
Doable
Post by Doable » Mon Nov 28, 2016 12:07 pm
1. Try pasting the following quote into a text document.
2. Save it as "wideBandO2SensorAEMFailsafe.def".
3. In DET3 --> Setup --> Scales configuration, Load "wideBandO2SensorAEMFailsafe.def".
// scale definition
name = WIDE BAND AEM FAILSAFE AFR 8.5-18
linearize = 0
unit = AFR
minValue = 8.50
maxValue = 18.00
// ilosc miejsc po przecinku
precision = 1
// non linear sensors are defined by equation:
// value = coef5 * v^5 + coef4 * v^4 + coef3 * v^3 + coef2 * v^2 + coef1 * v + coef0
coef0 = 7.3125
coef1 = 2.375
coef2 = 0
coef3 = 0
coef4 = 0
coef5 = 0
twister814
Post by twister814 » Tue Dec 20, 2016 6:33 pm
Doable it seems you sent me a incomplete folder.The file you sent is invalid.
Jostar
Post by Jostar » Sun Jan 29, 2017 4:01 am
I will try to see if Doable's file work at home, subscribe for any updates.
Jostar
Post by Jostar » Sun Feb 12, 2017 6:47 pm
I think I got it to work.
twister814
Post by twister814 » Fri Apr 07, 2017 4:03 am
Any info ???
