Can someone send me a screenshot or a base map of how to set the correlation between cam and crank and what settings to use to achieve crank sync. I am coming from AEM so I am used to the wizard doing this job for me. I did some searching and I haven't found anything specific. Thank you.
It is the standard 36-2 crank wheel and the 3 tooth cam trigger with equal spacing.
JZX100 1JZ VVTi Crank and Cam Settings
Re: JZX100 1JZ VVTi Crank and Cam Settings
I don think that 3equal teeth on cam will work, on my car i will grind off 2 of them and use only one
I will belive in that if they will not be equaly spaced... but of course i can be wrong...
Shame on me... i missed that one in secondary trigger setup....
Thanks Karel. Exactly what I was looking for. I've noticed you are very helpful in other posts. Thanks for all your help for everyone.
