Hello, since the car doesnt have a IAT sensor, how would the wiring be done to the DET3?
Ground -> sensor -> Analog#4 IN(pin16) ???
Or should the +5V Output be used with a Resistor trough the sensor to the Analgo in beeing the resistor value the one used in RX on calibration Menu?
+5V out(pin12) -> XXK Resistor -> Sensor -> Analog #4 IN(pin16) ??
BTW it is a Vauxhall Calibra Turbo (C20LET) Threaded 2 pin IAT(is this the GM IAT type in default sensor Types)??.
Thank you!
IAT sensor wiring
Re: IAT sensor wiring
ok, nevermind, that is on the FIT Manual and i guess the +5V out is good for this.
Is it just me or it looks like everytime we take a look at the manual there allways seems to be something new on it...
in case someone comes with the same doubt...
- IATsensor.png (6.9KiB)Viewed 5087 times
- ktsirigotakis
5v from det3 to one pin of clt and other pin to analog 4
Yes, thats how i have done, but with a 2k resistor on it which was i had in handy, and seems to be working ok!
ill make my own Knock detector/analyser now and i should be fine to start tuning it properly as soon as the wideband arrives!
thanks!
thanks!
- ktsirigotakis
don't blow up the engine good lack
First off, sorry for bumping such an old thread.
My question is with the IAT, I'll be using a GM unit. There's also a preloaded scale from ECUMasters built into the DET3. If I hook up the IAT, will I still have to run a resistor?
