egt plugs
astra vxr
egt plugs
Post by astra vxr » Mon Jan 26, 2015 10:54 am
when conecting egt to the ecu do you have to use the proper plugs ( yellow ) or can you use others or wire direct to ecu loom ?
many thanks
Re: egt plugs
Post by Jadzwin » Mon Jan 26, 2015 5:15 pm
You need to connect thermocouples with the orginal wires up to EMU connector. If your EGT probe cables are to short you can expand them only with the special compensation cables. You cannot use stadard wires.
astra vxr
Re: egt plugs
Post by astra vxr » Mon Jan 26, 2015 5:19 pm
egt probs come with no conectors just bare wire ends so do i
1. join to ecu with loom wires
2 add plugs to both egt and ecu
as ecu is just wires for egt i wasnt to sure
thank you
Re: egt plugs
Post by Jadzwin » Mon Jan 26, 2015 5:46 pm
Just crimp it with the terminals. If you want to have connectors you need to buy thermocopule compensation connectors
astra vxr
Re: egt plugs
Post by astra vxr » Tue Jan 27, 2015 3:45 pm
why do i need then if i wanted them on plugs ??? sorry if i sound thick but whats the difference if i crimp them or use "proper " plugs
this is what i wanted to do
all 4 runners have egt sensors in ( probe with 1meter cable ) as it stands we can only use 2 egts on the ecu so i was going to use 2 at a time and swap to check other ports when on the dyno as well check other things
but whats the difference im me crimping them to ecu loom ( using pink and white from loom kit ) or useing say amp seal plugs instead of the proper plugs
Re: egt plugs
Post by Jadzwin » Tue Jan 27, 2015 11:43 pm
The thermocouple measures difference of temperature between thermocouple tip and therocouple end. So it is important to measure temeperature of thermocouples end wire (the temp. sensor is located in EMU connecor). So to get proper readings the thermocouple wires need to be connected as near of the connector as possible.
astra vxr
Re: egt plugs
Post by astra vxr » Tue Jan 27, 2015 11:50 pm
think i got it now :oops:
so im going to have to change me egt probs for longer lead versions and conect them to the ecu direct or better still wait for the can version to come out and use that :)
these are the type im useing
Re: egt plugs
Post by Jadzwin » Wed Jan 28, 2015 12:48 am
In next week we will have EGT2CAN devices ready.
astra vxr
Re: egt plugs
Post by astra vxr » Wed Jan 28, 2015 12:51 am
spot on thank you :)
what sort of price range and does it come with senors etc
thanks again
ktsirigotakis
Re: egt plugs
Post by ktsirigotakis » Wed Apr 01, 2015 3:54 pm
Hi to all quick question how can i determinate egt probe polarity?
because i wired up my egt and i don't have egt temp indication is 0 all the time .
derOJ
Re: egt plugs
Post by derOJ » Wed Apr 01, 2015 5:43 pm
just switch polarity and see what happens :P :mrgreen:
Re: egt plugs
Post by Jadzwin » Thu Apr 02, 2015 10:43 pm
Here is a table for standard colors of thermocouples. EGT probes for EMU must be K Type one.
ktsirigotakis
Re: egt plugs
Post by ktsirigotakis » Mon Apr 06, 2015 11:45 am
thanks this list is very useful
ktsirigotakis
Re: egt plugs
Post by ktsirigotakis » Wed Apr 08, 2015 1:01 pm
hi to all i swap the wires and still don't have egt readings? i have a small 10cm copper cable from emu to sensor and the other one to sensor ground.
ktsirigotakis
Re: egt plugs
Post by ktsirigotakis » Mon May 11, 2015 11:45 am
i still don't have egt signal in emu please see the pic, i have approximately 10cm of copper wire from egt plugs to emu plug
thanks in advance
