egt plugs
Re: egt plugs
You need to connect thermocouples with the orginal wires up to EMU connector. If your EGT probe cables are to short you can expand them only with the special compensation cables. You cannot use stadard wires.
Re: egt plugs
egt probs come with no conectors just bare wire ends so do i
1. join to ecu with loom wires
2 add plugs to both egt and ecu
as ecu is just wires for egt i wasnt to sure
thank you
thank you
Re: egt plugs
Just crimp it with the terminals. If you want to have connectors you need to buy thermocopule compensation connectors
Re: egt plugs
why do i need then if i wanted them on plugs ??? sorry if i sound thick but whats the difference if i crimp them or use "proper " plugs
this is what i wanted to do
all 4 runners have egt sensors in ( probe with 1meter cable ) as it stands we can only use 2 egts on the ecu so i was going to use 2 at a time and swap to check other ports when on the dyno as well check other things
but whats the difference im me crimping them to ecu loom ( using pink and white from loom kit ) or useing say amp seal plugs instead of the proper plugs
Re: egt plugs
The thermocouple measures difference of temperature between thermocouple tip and therocouple end. So it is important to measure temeperature of thermocouples end wire (the temp. sensor is located in EMU connecor). So to get proper readings the thermocouple wires need to be connected as near of the connector as possible.
Re: egt plugs
think i got it now
so im going to have to change me egt probs for longer lead versions and conect them to the ecu direct or better still wait for the can version to come out and use that
these are the type im useing
- egt.jpg (4.22KiB)Viewed 8875 times
Re: egt plugs
In next week we will have EGT2CAN devices ready.
Re: egt plugs
spot on thank you
what sort of price range and does it come with senors etc
thanks again
thanks again
- ktsirigotakis
Re: egt plugs
Hi to all quick question how can i determinate egt probe polarity?
because i wired up my egt and i don't have egt temp indication is 0 all the time .
Re: egt plugs
just switch polarity and see what happens
Re: egt plugs
Here is a table for standard colors of thermocouples. EGT probes for EMU must be K Type one.
- ktsirigotakis
Re: egt plugs
thanks this list is very useful
- ktsirigotakis
Re: egt plugs
hi to all i swap the wires and still don't have egt readings? i have a small 10cm copper cable from emu to sensor and the other one to sensor ground.
- ktsirigotakis
Re: egt plugs
i still don't have egt signal in emu please see the pic, i have approximately 10cm of copper wire from egt plugs to emu plug
thanks in advance
thanks in advance
