base map Mitsubishi Galant 4g64
Can someone share base map for Mitsubishi 4g64 2002 ? There are problems with the parameters Primary trigger and Secondary trigger
Now we have
Now we have
- 20170314_2101.emulog
- (456.83KiB)Downloaded 82 times
Re: base map Mitsubishi Galant 4g64
Now as in the maps from the evo, but the car does not work. Evo, two camshafts, 4g64 one camshafts. How to choose the right second trigger?roquete wrote:search here:
viewtopic.php?f=19&t=514&p=3515&hilit=evo3#p3464
4g64 may have SOHC or DOHC, which sensor do you have?
CAS module on the camshaft or crank and cam sensors separated?
I have SOHCroquete wrote:4g64 may have SOHC or DOHC, which sensor do you have?
two sensors, crank and cam sensors separated
sorry now i see you have already wired them up.
Just use the scope function of the software and post it here.
Here I savedroquete wrote:sorry now i see you have already wired them up.
- scope_201714_1633.emuscp
- (47Bytes)Downloaded 93 times
why are you using cam#2?
post your project file, and how many thooth does the primary trigger have?
roquete wrote:why are you using cam#2?
Very strange, once showed it, I saved it.
I will attach another file later.
- galant-4g64-T-560ccзапустилась (1).emu
- (77.95KiB)Downloaded 112 times
you have the same settings i have for a evo3 with cas on camshaft like this:
these are my settings:
if your trigger on crankshaft is only 2 teeth like this settings are ok maybie you need to enable pullup
