hey
I have m52 single vanos is there anybody there have wiring diagram for this ,will fly back diode need for this valve ? .
and I need some help for configuration for this setup.
thanks ppower
m52 need intake vanos konfig and wiring dia
Re: m52 need intake vanos konfig and wiring dia
m52 wiring diagram and pin-out attached
you will need flyback diodes for the idle valve
and you will need to change the cam sensor for an early non vanos VR sensor
- m52.pdf
- (444.73KiB)Downloaded 131 times
