Ford Edis coil pack
Escosn@arc
HI.I´ve been busy with Essie.Thanks for advice Partick
I have some protected cable left from my MS project.I think i use that for my coils.
yippee kay jeah M*therF***er!!!
Re: Ford Edis coil pack
Hi Guys,
I see that you have more experience with ford coilpacks than I do. I have one strange problem.
I have connected ford EDIS coilpack (1&4, 2&3) to EMU coil1 and coil2 outputs, +12V directly from battery (with fuse). I am using wasted spark ignition (without cam sensor).
Unfortunately, as I have observed with strobe light, 1st and 2nd cylinders are firing twice per cycle (correct), but 3rd and 4th cylinders are firing only once per cycle. I have tested this with two coilpacks, with both of them I had the same problem.
My connection is similar to this, but without capacitor:
viewtopic.php?f=19&t=343#p2012
Thank you for any suggestion, I am getting really sick of the Ford stuff.
Escosn@arc
Hi xmaniekx!
Have you measure the resistans of spark plug lead.And often the coil pack end of lead is easily damaged.
Resistan should be somewhere near 5 kohm.
Other false is that there is a problem in your EMU coil wire.?Measure the resistance of that wire too.(Bad contack??)
Hemppa...
Hemppa...
Hi,Escosn@arc wrote:Hi xmaniekx!
Hemppa...
the problem have been solved by buying brand new BERU coil
Now I am waiting for the roads to get finally dry at see how much boost will the coilpack take on, without getting the spark "blown off".
Thanks a lot,
Mariusz
You can't have 12v permanent from the battery you need to have switched 12v.
Sure, my +12V source is activated by relay, didn't mention about it.PSI-Motor wrote:You can't have 12v permanent from the battery you need to have switched 12v.
